Zum Hauptinhalt wechseln
Axess TA2513-10WT Speaker Replacement
Was du brauchst
  1. Axess TA2513-10WT Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Speaker Replacement: Schritt 2, Bild 1 von 3 Axess TA2513-10WT Speaker Replacement: Schritt 2, Bild 2 von 3 Axess TA2513-10WT Speaker Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Speaker Replacement: Schritt 3, Bild 1 von 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Remove tape attached to black and red speaker wires.
  6. Axess TA2513-10WT Speaker Replacement: Schritt 6, Bild 1 von 1
    • Identify the four speaker nodes.
    • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
  7. Axess TA2513-10WT Speaker Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
  8. Axess TA2513-10WT Speaker Replacement: Schritt 8, Bild 1 von 1
    • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
  9. Axess TA2513-10WT Speaker Replacement: Schritt 9, Bild 1 von 1
    • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
  10. Axess TA2513-10WT Speaker Replacement: Schritt 10, Bild 1 von 1
    • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
Abschluss
Steven Kavanagh
301 Reputation
3 Anleitungen geschrieben
Baylor, Team 6-3, Shaver Spring 2015 Mitglied von Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 373
