Zum Hauptinhalt wechseln
Azpen A701 Battery Replacement
Was du brauchst
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: Schritt 1, Bild 1 von 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: Schritt 2, Bild 1 von 2 Azpen A701 Battery Replacement: Schritt 2, Bild 2 von 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: Schritt 6, Bild 1 von 1
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Abschluss
Grant Harding
249 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 2-1, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 696
