Zum Hauptinhalt wechseln
Azpen A720 Battery Replacement
Was du brauchst
  1. Azpen A720 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Azpen A720 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Battery Replacement: Schritt 2, Bild 1 von 3 Azpen A720 Battery Replacement: Schritt 2, Bild 2 von 3 Azpen A720 Battery Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the rear casing.
  4. Azpen A720 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Locate the batteries' connection points.
  5. Azpen A720 Battery Replacement: Schritt 5, Bild 1 von 1
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
  6. Azpen A720 Battery Replacement: Schritt 6, Bild 1 von 2 Azpen A720 Battery Replacement: Schritt 6, Bild 2 von 2
    • Peel the black sticker off the battery to disconnect the wifi antennae.
  7. Azpen A720 Battery Replacement: Schritt 7, Bild 1 von 3 Azpen A720 Battery Replacement: Schritt 7, Bild 2 von 3 Azpen A720 Battery Replacement: Schritt 7, Bild 3 von 3
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
  8. Azpen A720 Battery Replacement: Schritt 8, Bild 1 von 2 Azpen A720 Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the old battery and replace it with the new battery.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ben
280 Reputation
2 Anleitungen geschrieben
Michigan Tech, Team 1-3, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 2,239
