Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver. The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  4. Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit:  Wie man Lötverbindungen herstellt und entlötet After switching out the old speaker, just follow the directions in reverse to finish.
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: Wie man Lötverbindungen herstellt und entlötet
    • After switching out the old speaker, just follow the directions in reverse to finish.
Abschluss
Mallory
331 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-5, Brown Winter 2015 Mitglied von USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 62
