Einleitung
Before you begin replacing or fixing the internal components of your tablet, you will need to take the cover off. Here, we will show you the necessary steps for how to correctly remove the cover.
Was du brauchst
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
After prying open all of the anchoring points, the cover will lift off of the tablet.
