Einleitung
While a clarinet is used in this guide, this technique could be used on other woodwind instruments. A pad on a clarinet needs to be replaced if it falls off or becomes damaged. In this case, the protective film on the pad has fallen off.
Was du brauchst
Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
If the pad is missing completely, skip to step 3.
Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
Squeeze a dot of super glue into the empty key.
Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
Using the screwdriver, press the pad down to secure it to the key
Hold the pad for 5 seconds to let the glue harden
Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
Let the instrument sit out for a few minutes to let the glue fully dry
Ein Kommentar
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
