Zum Hauptinhalt wechseln
B-Flat Clarinet Key Pad Replacement
Was du brauchst
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: Schritt 1, Bild 1 von 1
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: Schritt 2, Bild 1 von 1
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: Schritt 3, Bild 1 von 1
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: Schritt 4, Bild 1 von 1
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: Schritt 5, Bild 1 von 1
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: Schritt 6, Bild 1 von 1
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
Ziellinie
Rachel Strobel
101 Reputation
1 Anleitung geschrieben
Michigan Tech, Team S3-G7, Galliah Fall 2017 Mitglied von Michigan Tech, Team S3-G7, Galliah Fall 2017
MTU-GALLIAH-F17S3G7
1 Mitglied
Ein Kommentar
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,364
