Zum Hauptinhalt wechseln
BELLA TXG-DS14 Heating Plate Replacement
Was du brauchst
  1. BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: Schritt 1, Bild 1 von 2 BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: Schritt 1, Bild 2 von 2
    • Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
    • Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
  2. BELLA TXG-DS14 Heating Plate Replacement: Schritt 2, Bild 1 von 2 BELLA TXG-DS14 Heating Plate Replacement: Schritt 2, Bild 2 von 2
    • Turn the device onto its side and have the bottom surface face you.
    • Remove the 1.5 mm Phillips #1 screws from the bottom of the device. Rotate the screws counterclockwise with a Phillip's #1 screwdriver.
    • There should be 8 screws removed by the end of this step
    • Make sure to keep the screws in a safe spot
  3. BELLA TXG-DS14 Heating Plate Replacement: Schritt 3, Bild 1 von 3 BELLA TXG-DS14 Heating Plate Replacement: Schritt 3, Bild 2 von 3 BELLA TXG-DS14 Heating Plate Replacement: Schritt 3, Bild 3 von 3
    • Place the unscrewed bottom cover next to the device without damaging the cords by extending them.
    • Unscrew all the 1.2mm Phillip's #1 screw around the silver plate by rotating them counterclockwise with Phillip's #1 screwdriver to take the plate off.
    • There should be 6 screws removed by the end of this device
  4. BELLA TXG-DS14 Heating Plate Replacement: Schritt 4, Bild 1 von 2 BELLA TXG-DS14 Heating Plate Replacement: Schritt 4, Bild 2 von 2
    • Locate 8 silver holds that holds the silver plate and black cover together.
    • Use a 0.1mm Flathead screwdriver to bend the 8 silver folds toward the center of the circle to release the silver plate.
    • Be careful to not cut yourself on the sharp edges of the silver folds.
  5. BELLA TXG-DS14 Heating Plate Replacement: Schritt 5, Bild 1 von 1
    • Remove the silver heating plate and install the new one.
    • Fold the silver edges back into place and put the screws back in. For further reassembly , follow this guide in reverse order.
    • When installing the new silver heating plate, make sure to not over bend the silver edges as they can easily break.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Norma Velarde
130 Reputation
1 Anleitung geschrieben
UC Davis, Team S7-G6, Lore Fall 2018 Mitglied von UC Davis, Team S7-G6, Lore Fall 2018
UCD-LORE-F18S7G6
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Bella 1.6 txg-af15a
Basket and Drawers
Reinaldo Figueroa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 43
Insgesamt: 1,858
