Einleitung
An old spring inside the silver basket stopper could cause the basket to pop out as it loses elasticity and this guide will show how to replace it.
Was du brauchst
Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
Remove the 1.5mm Phillip's #1 screws from the bottom of the device by rotating it counterclockwise with a Phillips #1 Screwdriver.
You should find two connected black cylinders in the top left and right-hand corners of the device containing the two silver stoppers for the drawer.
Unscrew the 1.2mm Phillips #1 screws connected to the black cylinders by using the Phillips +1 driver, rotate it counterclockwise and remove it.
Once both cylinder covers are removed, you should be able to locate the spring and the silver stopper
Remove silver stoppers and springs from the black cylinders. Replace springs with new ones.
