Zum Hauptinhalt wechseln
How to tighten the belts on a ProtoCentre 999
Was du brauchst
Einführungsvideo
    • First you want to loose the screw from the belt holder with the help of a allen key by rotating it in anti clockwise direction as shown in figure.
    • Pull the belt out of the belt holder after loosing the screw.
    • Increase the number of belt teeth on the smaller side of the belt,
    • NOTE: Make sure that the belt moves through all the pulley and has not slipped of any of them
    • Insert and push the belt back into the belt holder.
    • Rotate the screw in clockwise direction to tight the belt with the help of a allen key.
    • At the time of tightening the belt, hold the end of the belt part, for not slipping, while tightening.
    • Check the belt Stringing of the belt,whether it is tight or not.
Abschluss
abhishek j
1.169 Reputation
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 102
