Zum Hauptinhalt wechseln
BEM Mojo 2 Charging Base Motherboard Replacement
Was du brauchst
  1. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Battery: Schritt 1, Bild 1 von 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Motherboard Replacement: Schritt 3, Bild 1 von 2 BEM Mojo 2 Charging Base Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
  5. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Motherboard: Schritt 5, Bild 1 von 1
    • Use the tweezers to remove the red wire attached to the motherboard.
  6. BEM Mojo 2 Charging Base Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team S1-G1, Johnson Spring 2018 Mitglied von Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 160
