Einleitung
When replacing the speaker motherboard is important to use this as a last resort if your speaker is not turning on. The buttons could be not functioning and that would be a problem with the charging base motherboard or simply cleaning the buttons. The reason to replace the speaker motherboard would be if the ON/OFF switch is broken and not working at all. This guide will show you how to replace the speaker motherboard.
Was du brauchst
Pull back the rubber corners to uncover the bottom screws.
Continue this process for all four 10 mm screws.
Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
Remove the bottom cover of the speaker.
Remove all of the wires from the speakers internal chip, utilizing the tweezers.
Remove the speakers battery from its metal base, utilizing the plastic opening tool.
Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
Remove the red/black wires in addition to the blue/white wires using the tweezers.
Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
