Was du brauchst
Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
Now lift the cover carefully.
Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
Carefully remove the BIOS battery from its holder.
Do not throw away the battery! In Switzerland, the electrical shops are obliged to accept all batteries and accumulators for disposal.
For reassembly, follow the instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Martin Kubica hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
