Was du brauchst
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
Remove the battery connector first.
Then gently peel off the BIOS stack itself.
For reassembly, follow the instructions in reverse order.
100%
Hier starten ›
