Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: Schritt 1, Bild 1 von 2 BLU Advance 4.0 Screen Replacement, Removing the back cover: Schritt 1, Bild 2 von 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: Schritt 2, Bild 1 von 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: Schritt 2, Bild 2 von 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: Schritt 2, Bild 3 von 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: Schritt 3, Bild 1 von 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jon Sclar
292 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 2,289
