Zum Hauptinhalt wechseln
BLU Dash 3.5 Screen Assembly Replacement
Was du brauchst
  1. BLU Dash 3.5 Screen Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 BLU Dash 3.5 Screen Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 BLU Dash 3.5 Screen Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Screen Assembly Replacement: Schritt 2, Bild 1 von 2 BLU Dash 3.5 Screen Assembly Replacement: Schritt 2, Bild 2 von 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: Schritt 3, Bild 1 von 2 BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: Schritt 3, Bild 2 von 2
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Screen Assembly Replacement: Schritt 4, Bild 1 von 2 BLU Dash 3.5 Screen Assembly Replacement: Schritt 4, Bild 2 von 2
    • Remove volume and lock buttons by lifting them gently from the casing.
  5. BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: Schritt 5, Bild 1 von 2 BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to lift the tab where the cable is connected.
    • Use the opening tool to pry the motherboard from the front face plate.
  6. BLU Dash 3.5 Screen Assembly Replacement: Schritt 6, Bild 1 von 2 BLU Dash 3.5 Screen Assembly Replacement: Schritt 6, Bild 2 von 2
    • Use opening tool to pry off the screen.
    • Use a soldering tool to melt the contact between the motherboard and the screen
    • Solder new screen contacts to the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeffrey Dlugosz
104 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-2, Garvin Fall 2015 Mitglied von Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 699
