Zum Hauptinhalt wechseln
BLU Dash 3.5 Volume and Lock Button Replacement
Was du brauchst
  1. BLU Dash 3.5 Volume and Lock Button Replacement, Battery: Schritt 1, Bild 1 von 3 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: Schritt 1, Bild 2 von 3 BLU Dash 3.5 Volume and Lock Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Volume and Lock Button Replacement: Schritt 2, Bild 1 von 2 BLU Dash 3.5 Volume and Lock Button Replacement: Schritt 2, Bild 2 von 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: Schritt 3, Bild 1 von 2 BLU Dash 3.5 Volume and Lock Button Replacement, Volume and Lock Button: Schritt 3, Bild 2 von 2
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Volume and Lock Button Replacement: Schritt 4, Bild 1 von 2 BLU Dash 3.5 Volume and Lock Button Replacement: Schritt 4, Bild 2 von 2
    • Remove volume and lock buttons by lifting them gently from the casing.
Abschluss
Paige Shirley
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G2, Harley Spring 2017 Mitglied von IUPUI, Team S1-G2, Harley Spring 2017
IUPUI-HARLEY-S17S1G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 176
