Zum Hauptinhalt wechseln
BLU Dash JR D140 Digitizer Replacement
Was du brauchst
  1. BLU Dash JR D140 Digitizer Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Digitizer Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Digitizer Replacement, Digitizer: Schritt 3, Bild 1 von 1
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Digitizer Replacement: Schritt 4, Bild 1 von 1
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Digitizer Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Digitizer Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Digitizer Replacement: Schritt 7, Bild 1 von 1
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Digitizer Replacement: Schritt 8, Bild 1 von 1
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Digitizer Replacement: Schritt 9, Bild 1 von 1
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Digitizer Replacement: Schritt 10, Bild 1 von 2 BLU Dash JR D140 Digitizer Replacement: Schritt 10, Bild 2 von 2
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathanael
233 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,195
