Einleitung
Screens on these phones can crack easily, using this guide you can have a clean brand new slick look again! It is also a nice way to get under the screen and remove dust particles.
Was du brauchst
Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
Starting from a corner, separate the panel from the frame using the plastic opening tool.
Using a spudger, lift the black ZIF connector at the top left corner of the phone.
When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
5 weitere Nutzer:innen haben diese Anleitung absolviert.
