Zum Hauptinhalt wechseln
BLU Dash Music 4.0 Speaker Replacement
Was du brauchst
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: Schritt 1, Bild 1 von 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: Schritt 3, Bild 1 von 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: Schritt 3, Bild 2 von 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: Schritt 4, Bild 1 von 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: Schritt 4, Bild 2 von 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: Schritt 5, Bild 1 von 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: Schritt 5, Bild 2 von 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: Schritt 5, Bild 3 von 3
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: Schritt 6, Bild 1 von 1
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 471
