Einleitung
Use this guide to replace the motherboard in your BLU Energy X.
Was du brauchst
Detach the battery from the mother board using a plastic opening tool.
Use a plastic spudger to remove battery.
Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
