Einleitung
The rear facing camera is located in the center of the top motherboard. To access the rear facing camera the the back of the phone will need to be opened and the top cover for the motherboard will need to be removed. The connection is a press fit.
Was du brauchst
Use plastic spudger to disconnect the camera from the motherboard
Remove camera
2 weitere Nutzer:innen haben diese Anleitung absolviert.
