Einleitung
In order to remove the bottom motherboard the battery will also have to be removed. Be aware that removing the battery will void the phone warranty. The bottom motherboard is attached to the phone with an adhesive that is simply lifted up.
Was du brauchst
Detach the battery from the mother board using a plastic opening tool.
Use a plastic spudger to remove battery.
Remove the five 4 mm JIS J000 screws from bottom plate
Remove the bottom casing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
