Einleitung
This guide will help you replace the rear-facing camera on the back panel of the BLU Grand M2. It is a five-step process and can be completed in as little as six minutes.
The process is of a moderate difficulty and requires five tools for completion.
Was du brauchst
Check the front panel and confirm you are repairing the BLU Grand M2 (figure 1)
Turn the device over and identify the the rear-facing camera (figure 2) This is what you will be replacing
Locate the two torx screws at the bottom of the phone and remove them using the T2 Torx Screwdriver.
Identify the back-panel camera in the left -hand corner of the open device. (Figure 1)
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use the Plastic Pry Tool to carefully to lift the tab on the right-hand side of the connector.
Carefully remove camera from housing using a pair of tweezers.
