Einleitung
If the phone has trouble turning on or charging properly, the battery may need to be replaced. This guide will explain how to access, remove, and replace your BLU Life X8 battery.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Once the back panel is off, locate the indent at the bottom of the battery.
Use your thumb to slip the battery out of the case.
Ein weiterer Nutzer hat diese Anleitung absolviert.
