Einleitung
Bring life back to your Blu Life XL with a new battery. This guide instructs you to detach the rear panel assembly and replace the battery.
For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
