Zum Hauptinhalt wechseln
BLU Life XL Rear Camera Replacement
Was du brauchst
  1. BLU Life XL Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 3 BLU Life XL Rear Camera Replacement, Rear Camera: Schritt 1, Bild 2 von 3 BLU Life XL Rear Camera Replacement, Rear Camera: Schritt 1, Bild 3 von 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Rear Camera Replacement: Schritt 2, Bild 1 von 2 BLU Life XL Rear Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Rear Camera Replacement: Schritt 3, Bild 1 von 2 BLU Life XL Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic prying tool in between the plastic frame and the device.
    • Keep the phone on the surface with its screen down.
  4. BLU Life XL Rear Camera Replacement: Schritt 4, Bild 1 von 2 BLU Life XL Rear Camera Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic prying tool to gently push the rear camera out from its socket.
    • Take the camera out and set it aside.
  5. BLU Life XL Rear Camera Replacement: Schritt 5, Bild 1 von 2 BLU Life XL Rear Camera Replacement: Schritt 5, Bild 2 von 2
    • Carefully place the new camera in the camera socket.
    • Apply a little force on the top of the camera to slide it in the socket.
    • Pop the camera in the socket and make sure its stable.
Abschluss
USF Tampa, Team S2-G5, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 245
