Zum Hauptinhalt wechseln
BLU Life XL Volume Control Buttons Replacement
Was du brauchst
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: Schritt 1, Bild 1 von 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: Schritt 1, Bild 2 von 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: Schritt 1, Bild 3 von 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: Schritt 2, Bild 1 von 2 BLU Life XL Volume Control Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: Schritt 3, Bild 1 von 2 BLU Life XL Volume Control Buttons Replacement: Schritt 3, Bild 2 von 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: Schritt 4, Bild 1 von 3 BLU Life XL Volume Control Buttons Replacement: Schritt 4, Bild 2 von 3 BLU Life XL Volume Control Buttons Replacement: Schritt 4, Bild 3 von 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
Abschluss
James Whitlow
342 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S2-G5, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 397
