Zum Hauptinhalt wechseln
Einleitung
Use this guide in order to replace a damaged/drained battery in your BLU Studio 5.0 II. Phone must be turned off before starting to replace the battery.
  1. Turn off your phone before disassembling the device.
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Use your finger to open the back case by slowly pulling it on the open slot. Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  4. Locate the opening slot at the bottom of the battery. Use your finger to lift the battery and remove it from the case. Use your finger to lift the battery and remove it from the case.
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Ricardo Sarabia
1.030 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 7-5, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 603
