Einleitung
Use this guide in order to replace a damaged/drained battery in your BLU Studio 5.0 II. Phone must be turned off before starting to replace the battery.
Use your finger to open the back case by slowly pulling it on the open slot.
Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
Locate the opening slot at the bottom of the battery.
Use your finger to lift the battery and remove it from the case.
3 weitere Nutzer haben diese Anleitung absolviert.
