Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will teach you how to replace the power button on your BLU Studio 5.0 II phone.
  1. Turn off your phone before disassembling the device.
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. Use your finger to open the back case by slowly pulling it on the open slot. Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Locate the opening slot at the bottom of the battery. Use your finger to lift the battery and remove it from the case. Use your finger to lift the battery and remove it from the case.
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  5. Locate the four 3mm screws on each side of the back panel.
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  6. Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone. With the help of your fingers, continue to remove the back case by sliding it through the opening. With the help of your fingers, continue to remove the back case by sliding it through the opening.
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  7. Locate the power button on the left side of the motherboard. Using a spudger or a pair of tweezers, carefully remove the power button yellow film attached to the motherboard. Using a spudger or a pair of tweezers, carefully remove the power button yellow film attached to the motherboard.
    • Locate the power button on the left side of the motherboard.
    • Using a spudger or a pair of tweezers, carefully remove the power button yellow film attached to the motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Ricardo Sarabia
1.042 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 7-5, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 8
Insgesamt: 540
