Zum Hauptinhalt wechseln
Einleitung
Use this guide in order to successfully remove and replace the rear-facing camera on your BLU Studio 5.0 II phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off your phone before disassembling the device.
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. Use your finger to open the back case by slowly pulling it on the open slot. Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Locate the opening slot at the bottom of the battery. Use your finger to lift the battery and remove it from the case. Use your finger to lift the battery and remove it from the case.
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  5. Locate the four 3mm screws on each side of the back panel.
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  6. Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone. With the help of your fingers, continue to remove the back case by sliding it through the opening. With the help of your fingers, continue to remove the back case by sliding it through the opening.
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  7. Locate the camera, which is centered on the upper part of the motherboard. Use tweezers to lift the camera slowly. Carefully pull the camera out of the motherboard.
    • Locate the camera, which is centered on the upper part of the motherboard.
    • Use tweezers to lift the camera slowly.
    • Carefully pull the camera out of the motherboard.
Abschluss
Ricardo Sarabia
1.030 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 7-5, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 252
