Zum Hauptinhalt wechseln
BLU Studio G Battery Replacement
Was du brauchst
  1. BLU Studio G Battery Replacement, Battery: Schritt 1, Bild 1 von 3 BLU Studio G Battery Replacement, Battery: Schritt 1, Bild 2 von 3 BLU Studio G Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    • Set back cover aside.
  2. BLU Studio G Battery Replacement: Schritt 2, Bild 1 von 2 BLU Studio G Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Set battery aside and insert new one .
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 340
