Zum Hauptinhalt wechseln
BLU Tank II Keypad Replacement
Was du brauchst
  1. BLU Tank II Keypad Replacement, Back Panel: Schritt 1, Bild 1 von 2 BLU Tank II Keypad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Keypad Replacement, Battery: Schritt 2, Bild 1 von 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Keypad Replacement, Front Panel: Schritt 3, Bild 1 von 2 BLU Tank II Keypad Replacement, Front Panel: Schritt 3, Bild 2 von 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Keypad Replacement: Schritt 4, Bild 1 von 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Keypad Replacement, Keypad: Schritt 5, Bild 1 von 3 BLU Tank II Keypad Replacement, Keypad: Schritt 5, Bild 2 von 3 BLU Tank II Keypad Replacement, Keypad: Schritt 5, Bild 3 von 3
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
Abschluss
David Kelchner
632 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S6-G2, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G2, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 141
