Zum Hauptinhalt wechseln
BLU Vivo 5 Mini SIM Card Replacement
Was du brauchst
  1. BLU Vivo 5 Mini SIM Card Replacement, SIM Card: Schritt 1, Bild 1 von 1
    • Locate small hole on the right side of the phone under the power button.
  2. BLU Vivo 5 Mini SIM Card Replacement: Schritt 2, Bild 1 von 1
    • With the use of the SIM Card Eject Tool gently insert the tool into the hole.
  3. BLU Vivo 5 Mini SIM Card Replacement: Schritt 3, Bild 1 von 1
    • After pulling out SIM card holder check to see if the SIM card is inserted correctly.
    • While holder is open remove SIM card to check for any potential debris blockage. (You can complete remove holder to check for full blockage.)
  4. BLU Vivo 5 Mini SIM Card Replacement: Schritt 4, Bild 1 von 1
    • After clearing all debris re-enter the holder into the phone.
    • At this time either re-enter the SIM card or replace with new SIM card and close holder back into phone
    • Power on BLU Vivo 5 Mini and check for updated settings
Abschluss
Kymari
725 Reputation
5 Anleitungen geschrieben
Sam Houston State, Team S15-G6, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G6, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 528
