Zum Hauptinhalt wechseln
BLU WIN HD LTE Battery Replacement
Was du brauchst
  1. BLU WIN HD LTE Battery Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: Schritt 2, Bild 1 von 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: Schritt 3, Bild 1 von 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: Schritt 4, Bild 1 von 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: Schritt 5, Bild 1 von 2 BLU WIN HD LTE Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Abschluss
2 Kommentare
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Antwort
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 648
