Zum Hauptinhalt wechseln
BLU WIN HD LTE Camera Replacement
Was du brauchst
  1. BLU WIN HD LTE Camera Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Camera Replacement: Schritt 2, Bild 1 von 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Camera Replacement, Frame Cover: Schritt 3, Bild 1 von 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Camera Replacement: Schritt 4, Bild 1 von 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Camera Replacement, Camera: Schritt 5, Bild 1 von 3 BLU WIN HD LTE Camera Replacement, Camera: Schritt 5, Bild 2 von 3 BLU WIN HD LTE Camera Replacement, Camera: Schritt 5, Bild 3 von 3
    • Pry off the low profile connector located on the right side of the camera device.
  6. BLU WIN HD LTE Camera Replacement: Schritt 6, Bild 1 von 1
    • Pull the camera out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 290
