Zum Hauptinhalt wechseln
BLU WIN HD LTE Frame Cover Replacement
Was du brauchst
  1. BLU WIN HD LTE Frame Cover Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Frame Cover Replacement: Schritt 2, Bild 1 von 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Frame Cover Replacement, Frame Cover: Schritt 3, Bild 1 von 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Frame Cover Replacement: Schritt 4, Bild 1 von 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
Abschluss
To reassemble your device, follow these instructions in reverse order. Ensure that all sides of the frame cover are firmly snapped on before replacing the screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tione Gooden
269 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 182
