Zum Hauptinhalt wechseln
BMW 2003-2010 5 Series Tail Light Bulb Replacement
Was du brauchst
  1. BMW 2003-2010 5 Series Tail Light Bulb Replacement, Tail light Bulb: Schritt 1, Bild 1 von 1
    • Open the trunk of the car to access the tail lights.
    • Remove the two 5 mm screws holding the panel cover in place.
  2. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 2, Bild 1 von 1
    • With a flathead screwdriver, turn the screws half a turn counterclockwise.
  3. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 3, Bild 1 von 1
    • With plyers, remove the screws.
  4. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 4, Bild 1 von 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 4, Bild 2 von 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 4, Bild 3 von 3
    • Pull up the trunk matt and remove it from the corner.
    • Pull up the panel by the tab.
    • The panel should lift right out.
  5. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 5, Bild 1 von 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 5, Bild 2 von 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 5, Bild 3 von 3
    • You will see the light bulb holster.
    • Turn the dial in the middle of of the black plastic light bulb holster.
    • Pull the holster out of the trunk bay.
  6. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 6, Bild 1 von 1
    • Grab the light bulb at the base and twist counterclockwise.
    • DO NOT TWIST THE BULB BY THE GLASS.
  7. BMW 2003-2010 5 Series Tail Light Bulb Replacement: Schritt 7, Bild 1 von 1
    • Pull out the bulb and repeat the process in reverse order with the new bulb to reassemble.
Abschluss
To reassemble, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S3-G5, Saloman Spring 2021 Mitglied von UMass Dartmouth, Team S3-G5, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G5
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 98
Insgesamt: 2,749
