Zum Hauptinhalt wechseln
BMX Handlebars Replacement
Was du brauchst
  1. BMX Handlebars Replacement, BMX Handlebars: Schritt 1, Bild 1 von 1
    • Locate the stem of the bike connecting the handlebars to the steerer tube of the fork.
  2. BMX Handlebars Replacement: Schritt 2, Bild 1 von 2 BMX Handlebars Replacement: Schritt 2, Bild 2 von 2
    • Remove the four bolts from the face of stem with a 6mm Allen key.
    • BMX bolts typically use a 6mm standard, but some equipment may differ.
  3. BMX Handlebars Replacement: Schritt 3, Bild 1 von 1
    • Remove the faceplate of the stem.
  4. BMX Handlebars Replacement: Schritt 4, Bild 1 von 1
    • Remove the old handlebars.
    • Place the new bars in the curved area of the stem where the old bars were located.
  5. BMX Handlebars Replacement: Schritt 5, Bild 1 von 1
    • Place the faceplate of the stem back on and align the screw holes.
  6. BMX Handlebars Replacement: Schritt 6, Bild 1 von 1
    • Insert the four screws back into the stem and tighten them half way with the 6mm Allen wrench.
  7. BMX Handlebars Replacement: Schritt 7, Bild 1 von 2 BMX Handlebars Replacement: Schritt 7, Bild 2 von 2
    • Align your handlebars so they are straight, balanced, and to your liking.
    • Tighten the bolts in an "X" pattern a half turn at a time.
  8. BMX Handlebars Replacement: Schritt 8, Bild 1 von 1
    • Pull up on your handlebars and make sure they are tight enough that they do not move.
Abschluss
To reassemble your device, follow these instructions in order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 686
