Einleitung
This guide will show the steps required to remove the motherboard from the device.
Was du brauchst
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
4 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Where do I can get the power supply?
where can i get the notherboard? 354437-0060
Please where can I get the motherboard
