Einleitung
This guide goes over the steps needed to remove the subwoofer from the device.
Was du brauchst
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
Remove the plastic insert.
Remove the three 15.5 mm PH2 screws holding the metal insert down.
Remove the metal insert.
Remove the three 19 mm PH2 screws holding the metal subwoofer cover down.
Remove the subwoofer cover.
Remove the subwoofer by pulling towards the back of the device while tucking the wire under the plastic enclosure.
Eine weitere Person hat diese Anleitung absolviert.
