Einleitung
This guide will use a hex 2.0 head to open the case, as well as tweezers to disconnect and remove the motherboard. This will allow you to access the battery located at the bottom of the case.
Was du brauchst
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Remove the nut and washer from the RF connector, located where the antenna was connected.
Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
Lift and pull out of place.
Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
