Einleitung
This guide will show you how to remove the top cover using a hex 2.0 head driver in order to access the modem and attached microSD card. With a pair of tweezers, you will be able to remove and replace the microSD card.
Was du brauchst
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
Lower the plate and gently pull the ribbon out of the face plate.
With your tweezers, slide the metal face plate to release the locking mechanism.
Lift the face plate and carefully remove the microSD card.
Ein Kommentar
Can my brck connect if it does not have the sim card and the SD card from the manufacturer?
