Einleitung
This guide will show you how to remove the top case of the device utilizing a hex 2.0 drive. This allows you to access the modem. Using a pair of tweezers, you can easily remove the modem and replace the ribbon connector located underneath.
Was du brauchst
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
Using your fingers, apply equal force to each side of the black tab to loosen the connection.
Slide the ribbon out from under the black tab.
