Einleitung
In this guide, you will learn how to replace the battery terminals
Was du brauchst
Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
Remove the top piece and place it aside, keeping the bottom half with the mechanics.
Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
Flip the device on its face and remove the battery terminals with a metal spudger.
