Einleitung
In this guide, you will learn how to remove and replace the individual LED lights inside the device
Was du brauchst
Place the device face down on a flat surface, so that the screws on the back are facing the ceiling.
Using a screwdriver loosen the four screws connecting the body of the device together.
Once unscrewed, take the back of the body and put it aside. We will be working with the front part of the device.
Using a plastic opening tool pop the light panel off. Be careful as to not rip any of the wires from the panel.
Carefully pull the LED lights off with a pair of tweezers. Once off, put in and connect a replacement.
Eine weitere Person hat diese Anleitung absolviert.
