Einleitung
Replacement of power switch of a Babyliss Ionic SL hairdryer.
Disassembly is very easy, but you will have to desolder and resolder a switch.
Was du brauchst
remove two special head screws from device handle. Special tool required.
carefully separate the two plastic parts. You might have to pry them open on both sides of the top part.
mark all cables for later reference.
ATTENTION: there is a capacitator/condensator close by, better to remove it to prevent contact with the hot solder iron.
Desolder switch prior to removing from casing.
carefully push switch from inside out.
You might have to use a pair of pliers and some force to release the switch from plastic casing.
thanks to your labels you know which cable goes where.
push the two plastic parts together
tighten the screws.
Congratulations, you are done!
