Zum Hauptinhalt wechseln
Back Panel
Was du brauchst
  1. Back Panel, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  2. Back Panel: Schritt 2, Bild 1 von 3 Back Panel: Schritt 2, Bild 2 von 3 Back Panel: Schritt 2, Bild 3 von 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  3. Back Panel: Schritt 3, Bild 1 von 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 501
