Zum Hauptinhalt wechseln
Back of Bookshelf Replacement
Was du brauchst
  1. Back of Bookshelf Replacement, Back of Bookshelf: Schritt 1, Bild 1 von 1
    • Gather all pieces of the bookshelf if it fell apart or the shelf itself is still together.
    • You will need two people to complete this project.
  2. Back of Bookshelf Replacement: Schritt 2, Bild 1 von 3 Back of Bookshelf Replacement: Schritt 2, Bild 2 von 3 Back of Bookshelf Replacement: Schritt 2, Bild 3 von 3
    • You will need to put the bookshelf back together by holding the sides together.
    • Drill new holes to insert new screws to reinforce the shelf. Use a 1/8 inch drill bit.
    • Put screws into the freshly made holes with 1/8 by 1 inch wood screws to bring it together.
  3. Back of Bookshelf Replacement: Schritt 3, Bild 1 von 3 Back of Bookshelf Replacement: Schritt 3, Bild 2 von 3 Back of Bookshelf Replacement: Schritt 3, Bild 3 von 3
    • Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
    • Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
    • Use the jig saw to cut the piece of plywood out following the lines you just drew.
  4. Back of Bookshelf Replacement: Schritt 4, Bild 1 von 3 Back of Bookshelf Replacement: Schritt 4, Bild 2 von 3 Back of Bookshelf Replacement: Schritt 4, Bild 3 von 3
    • Line your new piece of plywood that you just cut, up with the back of the bookshelf.
    • Make sure that the corners are lined up so that as you hammer in the nails it stays lined up and even.
  5. Back of Bookshelf Replacement: Schritt 5, Bild 1 von 2 Back of Bookshelf Replacement: Schritt 5, Bild 2 von 2
    • Start from the top and work your way down each side when putting the nails in so the board doesn't bow.
    • Use 2d penny nails and hammer them in along all four sides.
    • Five nails on each of the four sides is all you will need.
  6. Back of Bookshelf Replacement: Schritt 6, Bild 1 von 2 Back of Bookshelf Replacement: Schritt 6, Bild 2 von 2
    • The shelf has its new plywood backing, so you can stand it up and you will feel the immediate difference in the sturdiness of your new shelf.
    • Place the shelf in the room of your choosing and place your books on it, knowing that it will not fall apart.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 33
Letzte 30 Tage: 158
Insgesamt: 9,584
